How can I draw a perforated cylinder in COMSOL?
Posted 2024年11月24日 GMT+1 13:53 Electrochemistry, Geometry Version 6.2 5 Replies
I have attached a picture of the perforated cylinder which I needed to draw like it? I am using this cylinder in electrochemical module
Using only the drawing tools within Comsol, I would be able to create that geometry by building multiple cylinders and using the array and difference operations.
You should consider whether (1) the holes are essential to the problem you want to solve and (2) whether symmetry can be used to reduce the effort of drawing and computing the problem.
yes the holes are essential and affect the process greatly and the symmetry can be used. I want this holes to be 2D circles and to create a polar array and I can't do this 2 actions. Can you clarify how symmetry would help? Can you please write the actions in details as the geometry is the base for the simulation in my case? Thank you so much
In 6.3 there now is a ChapGPT option that can help you code this geometry built. In 6.2 I would create a thin cylinder that cuts through the bigger cylinder, and use the Array and/or Rotate functions to copy this small cylinder up, down, and around, and make more cuts.
-------------------René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
René has provided a bit more detail, and you can also go to
https://www.comsol.com/video/3d-geometry-tools-comsol-multiphysics
for a short tutorial on how to use the geometry construction tools.
About symmetry- you haven't shown the rest of the geometry but as drawn the cylinder has rotational symmetry so the problem might be solved in a pie-like domain with symmetry boundary conditions on the cut surfaces.
Using symmetry requires some thought but can really pay off in reduced computation time for a complex 3D geometry.
I don't know if it is relevant for your application but... I'll mention that for some physics it is possible to replace a thin perforated object with a (possibly internal) boundary condition defined on a surface drawn without any of the fine details; the grille condition in CFD is an example. When such an approach can be used, not only is geometry creation much quicker, but you save lots of time and memory on meshing and solving.
-------------------Jeff Hiller
Basic Rules
- Flaming: Do not post any messages that harass, insult, belittle, threaten, or flame another member or guest. Debates are fine, but argue with the point, not the person.
- Trolling: Do not post with the purpose of starting a dispute. Note that a person disagreeing with your opinion is not considered trolling; keep it civil, even if you are sure that the other person is wrong. Anything seen as trolling will result in you being banned.
- Spamming: Posts without content or containing nonsense waste space and everyone's time. Spam will be removed from the forum.
- Offensive Posts, Links or Images: Do not use profanity, racial, ethnic, religious, or other slurs or any other offensive material.
- Advertising: Posting of advertisements for products or services, links to auctions, affiliate links, links to promote websites, and so forth is not allowed.
- Disclosure of Personal Information: Do not disclose any other member's email, real name, address, phone number, IP address, or other personal information. This includes posting contents of emails and private messages without the sender's consent. Do not bring personal disputes into the forums. Bans and warnings issued to other users are considered personal information.
- Misleading Titles: The subject line of the post should be as informative as possible about the content of the post. This also reduces the amount of duplicate posts.
- Thread Hijacking: Taking a thread off-topic to pursue one's own agenda is not permitted.
- Piracy: Do not upload, post, email, transmit, or otherwise make available any content that infringes upon any patent, trademark, trade secret, copyright, or other proprietary rights ("Rights") of any party. This includes COMSOL model files created by a forged or illegitimate license.
- Honesty: Users must provide truthful information in creating their COMSOL Access account.
Posting Guidelines
- Write in English.
Disclaimer
