coupling Helmholtz equation and Mindlin plates
Posted 2009年8月3日 GMT+2 10:100 Replies
I'm trying to simulate a hollow cube (1 m x 1 m) consisting of Mindlin plates. The plates are not equally thick. I tried it with the same kind of approach as in the example of a tube sealed with a vibrating membrane. Everything works fine if I have just one elastic face and others are rigid. When I created another geometry with a plate and tried to couple it the same way as the first one Comsol solved the Eigenfrequencies, but the second plate had no effect on the pressure inside the cube. I named the extrusion variables of the second plate as
Name Expression
w2 w
w2tt wtt
Is this wrong?
Is there a simpler way to couple several geometries?
Pekka Makkonen
Name Expression
w2 w
w2tt wtt
Is this wrong?
Pekka Makkonen
Last Post 2009年8月3日 GMT+2 10:10
Hello pekka makkonen
