2013年4月14日 GMT+2 11:46
check your doc and the "wall" options, there should be a "moving wall option in there ..
2013年4月14日 GMT+2 13:11
hey,
Actually I needed the thickness of the film between the plates too as an output...so I was using the "Thin film Flow interface" to model the flow. So, I have 2 doubts...
Firstly,
Does one require a moving mesh interface to be coupled with Thin film for setting up the study??
Secondly,
How does one specify the velocity of the plates moving towards each other in the displacement field of the Thin film flow interface? I tried displacement =velocity * time but it didn;t quite work out for me....Could you suggest something in this regard?
hey,
Firstly,
Secondly,
2013年4月16日 GMT+2 14:02
hey,
I tried building the model with the moving walls option. However, the pressure and velocity profiles are not changing with time in a time dependent study. Could you suggest if something is wrong with the model?
Sarneet
hey,
Sarneet
Mikael Noerregaard Nielsen
2013年4月16日 GMT+2 19:56
Hey Sarneet
First of all, I am no expert on the subject but its very hard giving you advice without your model:-) The reason why I mention this is because it could be something in your boundary conditions or perhaps even inlet or outlet conditions.
Best of luck
Regards Mikael
Hey Sarneet
Best of luck
Regards Mikael
