Henrik Sönnerlind
COMSOL Employee
2013年5月2日 GMT+2 23:03
There is no restriction in the base vector system. Actually it is more general than most users want or need, since it can define non-orthogonal axes and axes which do not have unit length. But to make proper use of that, you have to be familiar with tensor calculus in non-orthogonal systems.
The simplest way of defining a pure rotation in the e.g. the xy plane is to fill in the cells with
cos(angle) sin(angle) 0
-sin(angle) cos(angle) 0
0 0 1
where angle can be a parameter for easy modification. In 2D only the upper left 2x2 matrix is needed.
For efficiency, select the "Assume orthonormal" checkbox.
In your case it may however be even easier to use a "Rotated system" Instead of the Base vector system.
Henrik
0 0 1
Henrik
2013年5月15日 GMT+2 23:04
Thanks alot, that was exactly what I needed!!
2013年8月14日 GMT+2 23:30
Hi All
I have a little problem with coordinate transformation using the Base vector coordinate system.
When I'm changing the coordinates e.g. from x,y,z to ------>>>> x1,y1,z1 as below:
x1=n1*(fxx*x+fxy*y+fxz*z)+n2*(fyx*x+fyy*y+fyz*z)+n3*(fzx*x+fzy*y+fzz*z)
x2=a1*(fxx*x+fxy*y+fxz*z)+a2*(fyx*x+fyy*y+fyz*z)+a3*(fzx*x+fzy*y+fzz*z)
x3=b1*(fxx*x+fxy*y+fxz*z)+b2*(fyx*x+fyy*y+fyz*z)+b3*(fzx*x+fzy*y+fzz*z)
Nothing changes in the equation view under Base Vector System!
I was just wondering why the expressions in the equation view for sys2.T11=sys2.T22=sys3.T33=1 & sys2.T12=sys2.T13=....=0
Hi All
