Moving a cell through a sensor
I am modeling a volume sensor which involves 2 electrodes in a micro-channel. Using pressure changes we move a cell in between the electrodes and measure the change in electrical current.
So far I have been able to take current measurements by manually moving the cell. Is there a way to do a sweep of the cell's position? And if so is it possible to extract a boundary integration value for each position of the cell into an excel file?
Eric
1 Reply Last Post 2009年8月5日 GMT+2 21:01
Posted: 2 decades ago 2009年8月5日 GMT+2 21:01
Hi Eric,
give a look in the support page " www.comsol.com/support/knowledgebase/browse/"under the category "ale/parametrized geometry".
I think you can find something which is useful for your model.
To export your data , try File/Export/Post-Processing data. You will create a txt file which can be imported in Excell.
Alessandro
Hi Eric, give a look in the support page "http://www.comsol.com/support/knowledgebase/browse/" under the category "ale/parametrized geometry". I think you can find something which is useful for your model. To export your data , try File/Export/Post-Processing data. You will create a txt file which can be imported in Excell. Hi Alessandro
