how to estimate the parameters in PDE/ODE equations
Posted 2009年8月6日 GMT+2 09:181 Reply
In my research, I have been dealing with mass transport processes in porous media. I used several coupled PDE/ODE equations to depict the physical process. The values of some critical parameters, such as diffusivities, are unknown to me. What I typically did was first assuming the values of those parameters, then using Comsol Multiphysics to solve the Equations and getting the profile of a variable with respect to time, then compare this model predicted profile with the experimental data. If these two can match, I accept the original assumptions, otherwise, I have to re-assume the values of those parameters, and repeat the above process till the model prediction well match the experimental results. We can imagine the above procedure is very tedious, time-consuming and low-efficient.
I was wondering whether this is a way to design an algorithm for auto-data fitting with Matlab to quickly figure out the values of those unknown parameters? Or please show me some of such examples if you know.
Thank you very much!
Jacky
Jacky
1 Reply
Last Post 2009年11月29日 GMT+1 02:36
Hello JUNPIN YAO
