Sven Friedel
COMSOL Employee
2013年8月19日 GMT+2 11:31
Dear Eyal,
the attached model illustrates on a 1D model how what you want can be achieved.
The envelope of the temperature (maximum in time), can be obtained by integrating an additional domain ODE.
The integration of parts of the envelope that are located in a certain interval can be achieved by integration in derived values.
Given the special circumstances I leave the details up to you. We can talk about it tomorrow.
Sven
Dear Eyal,
Sven
Gunnar Andersson
COMSOL Employee
2013年9月2日 GMT+2 13:41
You can use a 1D histogram plot for this. E.g.,
1. Add a 1D Plot Group.
2. Set Time selection to Last.
3. Add a Histogram plot.
4. Set Entry method to Limits.
5. Set Limits to 0 45 50 55 60 65 100.
6. Set Normalization to Integral.
Eyal Spier
COMSOL Employee
2013年9月3日 GMT+2 08:31
Dear Gunnar,
Many thanks - I applied Sven's method and it seemed to do the trick! Thanks again for taking the time,
Eyal
Dear Gunnar,
Eyal
9 years ago
2015年12月21日 GMT+1 01:46
Hi Sven,
I tried to evaluate the largest value in solid mechanics, and the variable of interest is solid.mises. I used the same way as indicated in your model, but neither 'solid.misest' nor 'd(solid.mises)/dt' works. Do you have any suggestions? Mine is the 2D case.
Thanks a lot.
REgards,
Albert
Hi Sven,
Thanks a lot.
REgards,
Albert
9 years ago
2015年12月21日 GMT+1 07:55
none of you two variable names, formulas do work in COMSOL, the dependent variables (in solid u,v,w) not solid.mises has a derived value defined. You could try the derivative operator d(solid.mises,t) but check in the doc why you should rather use "TIME" the mesh time, instead of "t" solver time.
Sven Friedel
COMSOL Employee
9 years ago
2015年12月21日 GMT+1 09:33
Hi Albert,
Meanwhile we have introduced new ways of tracking maxima that would not require derivatives.
ch.comsol.com/blogs/tracking-material-damage-with-the-previous-solution-operator/
If you would like to implement the "old school" way for variables that have no built-in time derivatives or for which d(expression,t) would not work, the solution would be to define an additional domain ODE solving
u = expression
and then use ut or d(u,t). However, the approach with the previous operator should now be preferred.
Sven
Hi Albert,
https://ch.comsol.com/blogs/tracking-material-damage-with-the-previous-solution-operator/
u = expression
Sven
9 years ago
2015年12月22日 GMT+1 07:03
Hi Sven,
Thank you for the suggestion. I tried to use this method today by using:
u3-nojac(if(solid.mises>u3,solid.mises,u3)) where u3 is the dependent variable in ODE. I also set the damping coefficient to 0 as indicated in the blog. But what I got was not the maximum value of solid.mises during the time-dependent study.
When I randomly chose a point to evaluate solid.mises, it showed a realistic curve (shown in attached figure). However, when I evaluated u3 for the same point, it showed a monotone increasing trend (shown in the other figure attached), which is not correct. Do you know why did this happen?
Thanks a lot for the help.
Albert
Hi Sven,
Albert
9 years ago
2015年12月22日 GMT+1 07:04
Hi Ivar,
Thanks for the suggestion. Indeed, I need to use "TIME" instead of "t".
Albert
Hi Ivar,
Albert
