Modelling of a compressible fluid
I'm already a "medium level" user of COMSOL (Vers. 3.5), but as an electrical engineer, I'm lacking in the needed physics knowledge for the following problem:
I'd like to understand gas flow a little bit better in a PECVD system I've developped. I'd like to modell the gas flow from the entry point of the showerhead (which distributes the gas in the recipient) until the exit (pumping port) of the recipient.
(For those of you not familiar with a PECVD system: The process gas enters the reaction chamber through a flat, hollow plate with an array of small holes drilled in it, called showerhead. From the showerhead, the gas spreads out evenly onto the substrates, where it reacts to a solid substance, with the help of heat and plasma).
With the humble knowledge I have in fluid modelling, I guess that this problem can't be modelled with the incompressible navier-stokes, as the process gas enters the showerhead with a quite high pressure (500 - 1000 mbar absolute), while the pressure in the reaction chamber is only some 2 - 10 mbar absolute.
For me it's important to see the flow properties before and after the small holes in the showerhead. So the model has to include the strong decrease in gas density, when the gas streams out of the showerhead.
Is there a way to solve this problem with COMSOL with moderate expense of time?
Could this be done somehow with the Euler-Equation or a modification of the incompressible mode?
-A 2D-Model / 2D-Axisymmetric-Model is enough.
-Heat transfer can be neglected.
-I'm happy with a approximative result. I don't need 99.9% match to reality.
Many thanks for your help in advance!
Alex Stettler
1 Reply Last Post 2009年11月9日 GMT+1 17:07
Hello Alexander Stettler
Posted: 1 decade ago 2009年11月9日 GMT+1 17:07
I am a beginner at using COMSOL and i also have electrical engineering background. I am trying to model the gas flow inside the plasma etch reactor having the gas inflow through an annulus (which distributes the gas in the reactor) until the exit (pumping port) of the reactor. I am operating in the pressure range of 10-50mTorr.
I want to model the time multiplexed ("e.g;switching the gas at the input after every two seconds at a known flowrate") gas flow (transport) inside a reactor and see how one gas replaces the other inside the reactor.
Is there a way to solve this problem with COMSOL ...
-A 2D-Axisymmetric-Model is enough.
Thanking you in anticipation....
Iqbal
Hi I am a beginner at using COMSOL and i also have electrical engineering background. I am trying to model the gas flow inside the plasma etch reactor having the gas inflow through an annulus (which distributes the gas in the reactor) until the exit (pumping port) of the reactor. I am operating in the pressure range of 10-50mTorr. I want to model the time multiplexed ("e.g;switching the gas at the input after every two seconds at a known flowrate") gas flow (transport) inside a reactor and see how one gas replaces the other inside the reactor. Is there a way to solve this problem with COMSOL ... -A 2D-Axisymmetric-Model is enough. -Heat transfer can be neglected. -I'm happy with a approximative result. Thanking you in anticipation.... Best regards, Iqbal
