extrude/rotate different domains of a workplane from JAVA
Posted 2014年10月29日 GMT+1 15:22Version 4.40 Replies
I would like to extrude/rotate different domains of a workplane from JAVA, in a controlled way - i.e. avoid the explicit domain numbers because they might change if I make modifs in the geometry upstream.
How can this be done? I can create selections in the workplane geometry (either using a cumulative selection, or using a ball-selection for example based on coordiantes), but these selections are not selectable from the Extrude/Rotate nodes.
Thank you
Daniel
Thank you
Daniel
Last Post 2014年10月29日 GMT+1 15:22
Hello
