server port
Posted 2009年8月21日 GMT+2 14:350 Replies
I use the below command for the connection to the server:
comsol server -timeout 600 -port 42632 -multi on
The server starts and works well during connection.
When timeout value is passed, it can successfully reinitialise several times during connection. After being disconnected from server, when I start to use the same command for the reconnection, it shows the below message error:
Starting server. Please wait.
COMSOL server failed!
Error: Could not create server socket. Try again or a new port number.
Stack trace:
java.lang.RuntimeException: Could not create server socket. Try again or a new port number.
at com.femlab.server.FemlabServer.(Unknown Source)
at com.femlab.server.FemlabServer.main(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at com.femlab.server.Launcher.main(Unknown Source) Press Enter to quit!
I have tried several times with different timeout values, but it happens when this time out value finishes, the reinitialisation during connection is ok but for the reconnection the port doest not answer.
Has anyone faced the same problem?
Kamal
Stack trace:
Kamal
Last Post 2009年8月21日 GMT+2 14:35
Hello Kamal Shahim
