Heat transfer with time derivative heat source
Dear all,
I try to model heat transfer with time derivative heat source Q=dq/dt, with q=Qm*exp(Tau/t)^(Beta)
Qm, Tau, Beta are constant.
Are there anyone know how write dQ/dt in COMSOL?
I have tried either qt or d(Qm*exp(Tau/t)^(Beta),t) but both of them doesn't work.
I got the following error:
Failed to evaluate variable Jacobian.
- Variable: qt
- Geometry: 1
- Domain: 1
- Feature: Time-Dependent Solver 1 (sol1/t1)
Thank you for any help.
Agus
3 Replies Last Post 2015年6月3日 GMT+2 17:34
Posted: 10 years ago 2015年6月3日 GMT+2 06:21
In addition, when I used Q as d(Qmax*exp(-(Tau/t)^(Beta)),t), I got the error below:
Failed to find consistent initial values.
Last time step is not converged.
Can you help me?
Thanks.
Agus
In addition, when I used Q as d(Qmax*exp(-(Tau/t)^(Beta)),t), I got the error below: Failed to find consistent initial values. Last time step is not converged. - Feature: Time-Dependent Solver 1 (sol1/t1) Can you help me? Thanks. Agus
Posted: 10 years ago 2015年6月3日 GMT+2 07:55
It is of course possible to calculate the derivative in closed form:
dq/dt = -[(Qm·beta·Tau)/t²]*exp(beta·Tau/t)
The problem is that at t = 0 this has a singularity, as well as q itself. Your error message probably is related to that.
It is not my business, but from where such a peculiar function? Usually you see the form exp(t/Tau) where Tau is some characteristic time of the system.
br
Lasse
Hi It is of course possible to calculate the derivative in closed form: dq/dt = -[(Qm·beta·Tau)/t²]*exp(beta·Tau/t) The problem is that at t = 0 this has a singularity, as well as q itself. Your error message probably is related to that. It is not my business, but from where such a peculiar function? Usually you see the form exp(t/Tau) where Tau is some characteristic time of the system. br Lasse
Posted: 10 years ago 2015年6月3日 GMT+2 17:34
Hi Lasse,
Thank you very much for your quick respond.
I agree with you that at t = 0 this has a singularity.
From your answer above, I got new idea to avoid t=0 by changing t to very small values for instance t=0.0001.
It is working properly.
Regarding to the function, it is typical function describing the heat produced by the hydration reaction of cement-based materials. It is also mentioned in the several literature's.
Anyway, thank you very much for your answer. It gave me fresh inspiration to solve it.
Br
Agus
Hi Lasse, Thank you very much for your quick respond. I agree with you that at t = 0 this has a singularity. From your answer above, I got new idea to avoid t=0 by changing t to very small values for instance t=0.0001. It is working properly. Regarding to the function, it is typical function describing the heat produced by the hydration reaction of cement-based materials. It is also mentioned in the several literature's. Anyway, thank you very much for your answer. It gave me fresh inspiration to solve it. Br Agus
