identity pairs setting
Posted 2009年6月29日 GMT+2 13:350 Replies
Hi all,
I am looking for simulate a mechanical joint among sheet metal parts. During the first step parts have to be clamped (so contact pairs are defined). Then, once the contact is assured a mechanical joint (such bolt, glue, spot weld) is introduced. In this phase I assume that the mechanical joint is rigid and the I'd like to model it with an identity pair. The problem is: is it possible to change the tolerance value (if it exists) which comsol uses to detect if two boundaries are identity or not?
Thanks for your attention
Regards
Pasquale
Regards
Pasquale
Last Post 2009年6月29日 GMT+2 13:35
Hello Pasquale Franciosa
